orthomosaic
rananna
orthomosaic
by rananna » Wed Nov 15, 2017 1:35 pm
I am not having much luck using autopano giga to create an orthomosaic style of stitch.
( i have aerial photos where the camera is moving linearly over the ground (moving and the overlap is about 50%)
I have followed the guide here:
http://www.kolor.com/wiki-en/action/vie ... _stitching
do you have any other suggestions for getting this to work?
olivierbo
Liked in: 134 posts
Re: orthomosaic
by olivierbo » Wed Nov 15, 2017 2:18 pm
You do not need to set a lot of parameters if you shoot properly. What's wrong with your pano? A screenshot would be useful?
Did you shoot using an app like Dronepan for instance? Dis you shoot in multiple lines and columns?
Best regards,
Olivier
rananna
Re: orthomosaic
by rananna » Wed Nov 15, 2017 2:22 pm
I am not trying to shoot a panorama like dronepan does where the drone is stationary and rotates to capture the photos.
Rather I am moving in a grid pattern over a scene with the camera pointing stright down and overlapping each photo by about 50%. I would like to stitch the mosaic together.
This type of photo is often called an orthomosaic if it is geo referenced.
ie see: https://medium.com/new-farmer/what-is-a ... 140c0601df
olivierbo
Liked in: 134 posts
Re: orthomosaic
by olivierbo » Wed Nov 15, 2017 2:24 pm
Have you tried to import your pictures with Gigapan import module?
How do you proceed?
Best,
Olivier
rananna
Re: orthomosaic
by rananna » Wed Nov 15, 2017 2:28 pm
I do not use the gigpan imprt as my understanding is that this is for stationary panoramas. I simply import the photos using file select images. I then press detect.
rananna
Re: orthomosaic
by rananna » Wed Nov 15, 2017 3:40 pm
OK I got it to work with the following settings:
force focal length to 400mm.
Under "group settings" > "optimization", "Optimization stages (manual)", and uncheck "initial lens distortion" and "Final lens distortion" * check local/global,first optimiation, geom analysis, bad points and bad links
optimization scope settings: optimize everything (focal, distortion, offset and viewpoint)
Panoram1x
Liked in: 41 posts
Re: orthomosaic
by Panoram1x » Wed Nov 15, 2017 5:08 pm
You can try this...
viewtopic.php?f=2&t=32642
...And there follow the links.
Try it, and tell us if it has been useful.
rananna
Re: orthomosaic
by rananna » Wed Nov 15, 2017 5:19 pm
That duplicates what I did in the last post.
Anyway, it continues to work with these settings
Panoram1x
Liked in: 41 posts
Re: orthomosaic
by Panoram1x » Wed Nov 15, 2017 5:46 pm
Ooops!
I was in a non-updated version of the thread, sorry :)
To see the problem, can you show some image? even partial.
