exposure and color correction not working on the export
bbbence
Likes: 3 posts
by bbbence » Sat Sep 23, 2017 2:51 pm
I did a gigapixel panorama of the stars with a Roundshot VR Drive, and stitched it with autopano with the papywizzard plugin. Unfortunately there is something wrong with the exposure compensation and color ballance between the images, because the exported files is not seamless. It looks nice in autopano, but I can see the stitching lines on the exported file.
I used suto exposure, color, vignetting and gradient. I attached two screenshots to show the preview in gigapano, and how it looks on the exported file.. Why is that? is there anything I could do to get the same result as an on the preview?
Panoram1x
Liked in: 41 posts
Re: exposure and color correction not working on the export
by Panoram1x » Tue Sep 26, 2017 8:30 am
Can you share the images and the .pano file? (Public or private) to be able to investigate what is the way to obtain a good result
bbbence
Likes: 3 posts
by bbbence » Fri Sep 29, 2017 2:52 pm
I've deleted those panos since then, but the problem headed up again. I created another project then tried modifying color mode and blend settings and the current result is the best I could done. Do you have any solution for the problem?
Arrows indicate exposure/color correction problems at stitching lines.
kereszt.pano
Pano project file.
(10.28 MiB) Downloaded 50 times
olivierbo
Liked in: 134 posts
by olivierbo » Fri Sep 29, 2017 3:10 pm
Pictures are also needed ;)
Best,
Olivier
