Stiching errors in AP Pro - Canon T2i with Rokinon 8mm FE   [SOLVED] - View the solution
aunakhtar
by aunakhtar » Sat Aug 19, 2017 7:55 am
The autopano stitch
I am trying to stitch a 9 image 360 pano shot with Canon T2i and Rokinon 8mm Fisheye.
Another software (not sure if I am allowed to use the name) stitched the pano automatically first time correct to give the perfect 360 output but somehow Autopano is just not able to stitch it together.
I have set the multiplication factor at 1.6 and focal length as 8mm in Autopano
The files are available at https://drive.google.com/open?id=0B9kLt ... GxDUVh0cUE
I have tried different settings and tried to manually set the control points but it is just not working. Even in my earlier panos, I had to face a lot of difficulty stitching in Autopano vs the other software. The images are just so mis-aligned I do not know how to correct it.
Any help with this particular case will be greatly appreciated.
Thanks in advance!
Panoram1x
Liked in: 41 posts
Re: Stiching errors in AP Pro - Canon T2i with Rokinon 8mm F
by Panoram1x » Sat Aug 19, 2017 4:45 pm
z44-132-9.1 [IMG_1227].pano
(755.56 KiB) Downloaded 79 times
aunakhtar
by aunakhtar » Sat Aug 19, 2017 7:04 pm
Thanks but how did you do it? Is there something I was missing or did you have to do something manually to make Autopano detect the correct control points?
TIA.
Panoram1x
Liked in: 41 posts
Re: Stiching errors in AP Pro - Canon T2i with Rokinon 8mm F  [SOLVED]
by Panoram1x » Sat Aug 19, 2017 8:37 pm
Basically what I've done is a bit of manual work
# 1 I've charged the images in Autopano, except image 8 (images 8 and 9 are redundant)
# 2 After adjusting the focal length for the lens and setting that it is a Fish Eye (in the image properties) ...launch detection ...
# 3 In the control point editor I have deleted the links between non-adjacent images (In this case I have removed links 1-5, 2-6 and 4-6)
# 4 On the first attempt there was a discontinuity on the horizon, that has been solved by adding some control points
# 5 Finally, optimize and vertical lines tool ... And render!
aunakhtar likes this post.
aunakhtar
by aunakhtar » Sat Aug 19, 2017 9:39 pm
Understood. So the links have to be in continuity (in sequence of the direction of the images)?
Panoram1x
Liked in: 41 posts
by Panoram1x » Sun Aug 20, 2017 5:46 pm
Yes it is. In this case the only links I have kept are -1-2-3-4-5-6- + zenith and nadir (only single image for each one)
