I need help with these stitches so close
ariel007
Likes: 4 posts
by ariel007 » Thu Jun 22, 2017 10:58 pm
Hello I would need help or a recommendation to finish this project. I am inside a car and I do not get a precise stitch, if someone can guide me it would be of great help !! I touch the control points .. the masks .. I change the size of each image but I can not get it ... thanks
Re: I need help with these stitches so close
by Destiny » Fri Jun 23, 2017 9:59 am
Hi.. Well it looks to me that your NPP setting is way out.. Also, you would be better off using bracketed exposers when capturing inside a car.. Your ISO is far too high causing graininess/noises in the images.. This will all impact on the control points effectiveness too..
What gear did you use to capture this pano..??
ariel007
Likes: 4 posts
by ariel007 » Fri Jun 23, 2017 2:12 pm
The capture I made with gopro Omni .. maybe have activated the protune of the camera that is why they look bad colors but then I work in photoshop .. my problem are the stitches
by Destiny » Fri Jun 23, 2017 11:08 pm
I see.. The GoPro Omni is a nice setup and I have seen some nice results, however capturing object in close proximity will not provide good results.
Destiny....
ariel007 likes this post.
olivierbo
Liked in: 134 posts
by olivierbo » Mon Jun 26, 2017 10:53 am
Try to put the Omni rig at 45°to have 4 cameras horizontally, one facing up and one facing down. It could help in some cases...but Fusion will do the job in a near future! ;)
Cheers,
Olivier
by Destiny » Mon Jun 26, 2017 1:00 pm
Olivier, regarding the Fusion.. Are you able to say if this camera will capture RAW and Bracketed shots.. There is so little info on this new camera..
olivierbo wrote:Hello,
Cheers,
Olivier
olivierbo
Liked in: 134 posts
by olivierbo » Mon Jun 26, 2017 1:04 pm
Hi Destiny,
No new info regarding Fusion. Be patient!! ;)
Cheers,
Olivier
Users browsing this forum: No registered users and 11 guests
