raw import/ bridge plugin
mz7thc
by mz7thc » Tue Mar 24, 2015 9:43 pm
Just wonder when I import raw files from Adobe Bridge to APG, the files are changed to jpg. Is there a way around it to have a loss less file format? Opening the raw files directly in APG, the raw-settings are not imported.
Nanard
Liked in: 3 posts
Re: raw import/ bridge plugin
by Nanard » Wed Mar 25, 2015 11:30 am
Not sure what you mean by 'raw settings', but settings from Nikon NEF (raw) are proprietary informations and can only be interpreted by Nikon software. White balance is maybe the exception to the rule, for Nikon raws.
I use Lightroom, and it does not 'import' the raw settings from Nikon. Most probably the same for Canon, etc...
Most people develop their raw files in a dedicated software (Lightroom, DXO, Capture One,..) and export Tiff / 16 bits files to APG; for better quality and control.
Bernard
mz7thc
by mz7thc » Wed Mar 25, 2015 8:40 pm
That means the Bridge plug-in is basically useless...
Nanard
Liked in: 3 posts
by Nanard » Wed Mar 25, 2015 10:58 pm
Don't know Bridge.
Plug in is probably a handy way to go directly from Bridge to APG.
Within APG, raws are developed by DCRAW, you have no control and the quality is basic.
If you want control over the development and the best quality, you have to use a dedicated software.
Bernard
