Autopano 3 RC2 - no CUDA with 7x Cams   [SOLVED] - View the solution
traction
by traction » Mon Aug 07, 2017 3:55 am
I just upgraded as the watermark screws up CUDA processing and I really wanted to test this feature.
If I import 6 x 1440 GorPro files, I can get CUDA playback - realtime in 4K.
Autopano doesn't seem to want to use CUDA with 7 x cams.
I'm runnning latest everything on dual GTX980Ti's under WIn10 pro, 64GB RAM.
Nic
ClaireM
Liked in: 36 posts
Re: Autopano 3 RC2 - no CUDA with 7x Cams  [SOLVED]
by ClaireM » Mon Aug 07, 2017 8:12 am
Indeed for the moment CUDA accelerations are only supported for projects with less than 6 videos : http://www.kolor.com/wiki-en/action/vie ... w_features
(It says with 2 or 6, but with RC2 it has slightly changed since we are working on it, and the limitation is now less or equal to 6 cameras).
Best,
Claire
