Installation of AutopanoPro 4.4 RC1 fails on Debian
Michael Thaler
by Michael Thaler » Sun Mar 05, 2017 7:43 pm
I tried to install AutopanoPro 4.4 RC1 on Debian Testing (Stretch) and it fails with the following error:
# dpkg -i AutopanoPro_Linux64_440RC1_2017-03-01.deb
(Reading database ... 427538 files and directories currently installed.)
Preparing to unpack AutopanoPro_Linux64_440RC1_2017-03-01.deb ...
Unpacking autopanopro (440RC1) over (423) ...
dpkg: error processing archive AutopanoPro_Linux64_440RC1_2017-03-01.deb (--install):
 unable to open '/usr/lib/AutopanoPro/Resources/Translation/README.dpkg-new': No such file or directory
Processing triggers for shared-mime-info (1.8-1) ...
Unknown media type in type 'all/all'
Unknown media type in type 'all/allfiles'
Processing triggers for desktop-file-utils (0.23-1) ...
Processing triggers for mime-support (3.60) ...
Processing triggers for man-db (2.7.6.1-2) ...
Errors were encountered while processing:
olivierbo
Liked in: 134 posts
Re: Installation of AutopanoPro 4.4 RC1 fails on Debian
by olivierbo » Mon Mar 06, 2017 11:37 am
Can you try to use the .tar.gz package instead and let us know? We only test the software on Ubuntu.
Thanks in advance.
Best regards,
Olivier
Michael Thaler
by Michael Thaler » Tue Mar 07, 2017 9:34 am
If I have time, I try it tonight.
The reason for this problem could be that I also have the stable version of AutopanoPro (4.2.3) installed. See this post: https://raphaelhertzog.com/2011/07/18/d ... -dpkg-new/
If I have time tonight, I will try to purge the old version and install the RC1 again to see if this solves the problem.
