GoproVR premiere plugin & time remapping problem
mrcSoave
by mrcSoave » Wed Aug 17, 2016 3:00 pm
It seems that the key-frame of the VR reframe plugin are not taking into consideration time remapping, introducing an offset between the key-frame point and it's application to the video.
Marco
JeromeL
Re: GoproVR premiere plugin & time remapping problem
by JeromeL » Wed Aug 24, 2016 10:36 am
We actually noticed that problem. However, a temporary solution (which is often useful) is to nest the video on which you applied time remapping and then apply GoPro VR reframe (or Horizon) on the nested sequence (Nested sequence and original sequence must be the same size)
regards
