GoPro VR Plug-ins / Watermarks in Premiere Pro / OSX MAC   [SOLVED] - View the solution
kps219
by kps219 » Sun Aug 07, 2016 4:36 am
I am running the latest beta, and with premiere cc2015.3 on OSX 10.11.6
Even after activating AVP, I still get the gopro watermarks whenever I apply the GoProVR horizon/reframe effect on a layer.
I tried clean installs of premiere, avp.
Even cleaned cache files & everything
what can i do?
thats Emergency!!! =(
JeromeL
Re: GoPro VR Plug-ins / Watermarks in Premiere Pro / OSX
by JeromeL » Tue Aug 09, 2016 3:37 pm
Can you please open a terminal (Applications->Utilities->Terminal), type this command line:
ls -la ~/Library/Application\ Support/Kolor/
and post the result of the command?
kps219
by kps219 » Wed Aug 10, 2016 5:04 am
total 0
drwxr-xr-x   5 kps219  staff   170  8  6 00:59 .
drwx------+ 67 kps219  staff  2278  8  9 23:10 ..
drwxr-xr-x   4 kps219  staff   136  8  4 16:43 AutopanoVideoPro22
drwxr-xr-x   4 kps219  staff   136  8  4 16:55 AutopanoVideoPro23
drwxr-xr-x   4 kps219  staff   136  8  6 00:59 AutopanoVideoPro25
JeromeL
by JeromeL » Wed Aug 10, 2016 8:16 am
The problem should be in a wrong username/license key in one of your AVP versions.
For each of your AVP version (2.2, 2.3 and 2.5) can you please send us (in separate file) by private message the result of these command lines:
defaults read "com.kolor.AutopanoVideoPro22"
defaults read "com.kolor.AutopanoVideoPro23"
defaults read "com.kolor.AutopanoVideoPro25"
JeromeL
by JeromeL » Wed Aug 24, 2016 9:19 am
The AVP RC1 verion with a fix for watermarks is released. Let us know if any problems
Regards
