Problem with APVP wizard " import all go-pros"
mberajas
Likes: 3 posts
by mberajas » Mon Aug 01, 2016 11:33 pm
I have problem with Autopano video when I try to use the wizard " import all go-pros" I received an warming that there is not disk in the drive D: actually I connected my 6 go-pro cams by a hub, but the software does not recognize them! What can I do?
ClaireM
Liked in: 36 posts
Re: Problem with APVP wizard " import all go-pros"
by ClaireM » Tue Aug 02, 2016 3:10 pm
-> What kind of hub do you use?
-> Do you have any other devices connected to your computer via USB for instance (Phone...?) : if so, unplug them and try again.
-> If the previous step did not work, can you try the following workflow :
1. Close AVP
2. Open Regedit
3. HLM-System-Controlset001-Control-Windows-Errormode :Change value from 0 to 2
4. Close Regedit
5. ReOpen AVP and try again
Best,
Claire
