GoPro plugins / After Effects 2015.3 / Windows 10 error   [SOLVED] - View the solution
Guernegor
Liked in: 3 posts
by Guernegor » Sat Jul 23, 2016 3:36 pm
As you can see on this printscreen:
2 plugins are throwing an error in After Effects.
Is there a workaround?
With kind regards,
martin.arnoux
Liked in: 27 posts
Re: GoPro plugins / After Effects 2015.3 / Windows 10 error  [SOLVED]
by martin.arnoux » Mon Jul 25, 2016 9:56 am
These plugins are only meant for Adobe Premiere Pro, not for After Effects.
Cheers,
Martin
Guernegor
Liked in: 3 posts
by Guernegor » Tue Jul 26, 2016 9:54 am
Hi Martin,
How am I supposed to use them only in Adobe Premiere as they are installed in the Adobe/Common/Plug-ins which is shared amoung Adobe Software. Is there a way to tell AE to not load those plugins?
With kind regards,
cgolheiros likes this post.
JeromeL
by JeromeL » Tue Aug 02, 2016 3:39 pm
Sorry, for the moment there's no workaround on windows to avoid this popup except deleting plugins from common folder, this problem should be fixed in the next release of AVP 2.5.
Guernegor
Liked in: 3 posts
by Guernegor » Tue Aug 02, 2016 5:06 pm
Cool... Thanks!
