Entaniya 250 stitch preset problem
jpkela
by jpkela » Sun Jul 17, 2016 10:49 pm
I'm using 3 cam setup with Freedom360 rig & Ripcage modified Entaniya 250° lenses. For some reason the template stitch won't work ok. If I use 220° template, the resulting equirectangular is quite ok, but the stitching is not perfect. If I choose 250° template, the resulting stitch is totally messed up.
Is the 250° setup somehow targeted for back to back configuration only? What parameters should I use for 3 cam 250° setup?
martin.arnoux
Liked in: 27 posts
Re: Entaniya 250 stitch preset problem
by martin.arnoux » Tue Aug 02, 2016 9:45 am
Hi Juha,
Can you send me some 250° images to be stitched? I would recommend using the 250° preset and manually stitch using Autopano Giga.
Thanks,
Martin
