VR Reframe plugin crashing premierecc2015   [SOLVED] - View the solution
iamconan
by iamconan » Fri Jul 15, 2016 3:58 pm
Installed latest Premiere2015.3 last week and also installed beta of the AVP 2.5 latest build.
Now all clips which had previously had GoPro VR Reframe effects in them, the plugIn is no longer recognised and when i try to drop the plug in back onto a clip it crashes premiere with following error message.
On MacPro running ElCapitan 10.11.2
Any help on this greatly appreciated.
iamconan
Re: VR Reframe plugin crashing premierecc2015
by iamconan » Fri Jul 15, 2016 5:45 pm
Can someone advise on best practice for uninstalling all Kolor software on mac osx10.11 so i can try a fresh install to see if that works.
JeromeL
by JeromeL » Thu Jul 28, 2016 3:36 pm
First you should try a fresh install by following this documentation : http://www.kolor.com/wiki-en/action/view/AutopanoVideo_Solutions and then reboot your mac.
The latest AVP2.5 beta 3 has just been released, you should use this one for your fresh install.
Regarding Premiere plugins, Premiere crashes both with Horizon and Reframe or only with Reframe?
Regards
iamconan
by iamconan » Thu Jul 28, 2016 3:55 pm
Premiere crashes with both reframe and horizon. Thanks.
Phil360
by Phil360 » Sun Jul 31, 2016 4:06 am
I have the exact same problem. Premiere crashes with both reframe and horizon.
Trying this doesn't remove the two plugins for me. http://www.kolor.com/wiki-en/action/vie ... _Solutions
Phil
iamconan
by iamconan » Mon Aug 01, 2016 9:59 am
From the link provided i do not see a guide to totally uninstalling APV, just restoring default settings. Just dragging APV/APG to trash does not remove these plugins.
Could you provide steps to removing these plug ins from Premiere.
JeromeL
by JeromeL » Mon Aug 01, 2016 10:46 am
Sorry the information was missing.
These plugins should be located here: /Library/Application Support/Adobe/Common/Plug-ins/7.0/MediaCore/GoPro
You first have to delete manually "GoProVRHorizon.bundle" and "GoProVRReframe.bundle" and then reinstall the latest AVP 2.5 to get them back
iamconan
by iamconan » Mon Aug 01, 2016 12:22 pm
I don't appear to have a Plug-Ins folder within the Common folder on this machine. Anywhere else they could be?
JeromeL
by JeromeL » Mon Aug 01, 2016 1:58 pm
The previous path is located from your hard drive, usually named Macintosh HD (see screenshot enclosed if needed). If it doesn't appear from your finder you can display it by going to Finder->Preferences->Sidebar and then check Hard disks in Devices section
iamconan likes this post.
Phil360
by Phil360 » Mon Aug 01, 2016 3:53 pm
I did this.
"You first have to delete manually "GoProVRHorizon.bundle" and "GoProVRReframe.bundle" and then reinstall the latest AVP 2.5 to get them back"
Open Premiere and verify the plugin is gone. After reinstalling the latest AVP 2.5, I get the same error listed in the first post.
Any other ideas?
Phil360
by Phil360 » Wed Aug 03, 2016 1:33 am
Any help here?
JeromeL
by JeromeL » Wed Aug 03, 2016 9:33 am
Can you please remove the two plugins (as before in /Library/Application Support/Adobe/Common/Plug-ins/7.0/MediaCore/GoPro) and install a previous version of AVP 2.5 (beta 2 or beta 1) to test if they work with a particular version ? You can find former versions here: http://download.kolor.com/avp/beta/history
Phil360
Re: VR Reframe plugin crashing premierecc2015  [SOLVED]
by Phil360 » Wed Aug 03, 2016 1:57 pm
Jerome,
Same result using the other version. I started looking at other plugins and found that it was in combination with the Mettle plugin was causing the crash. After removing the Mettle (trial version) plugin, the GoPro VR plugins worked with the latest beta.
Thanks for your help!
JeromeL
by JeromeL » Wed Aug 03, 2016 2:03 pm
Your welcome Phil and thx for your feedback, It may help other users for that tricky case!
