Calibrate Wizard
daFonsi
Calibrate Wizard
by daFonsi » Wed Nov 04, 2015 10:35 am
Has anyone successfully used the Kolor Eyes VR headset Calibrate Wizard? I can't find any documentation and I can't get it to work properly, I get just the instructions (only on the right side) and a red meter that goes up and down. Otherwise the screen remains black. I use an iPhone 6 and Zeiss VR one.
Thanks, Fons
ygilquin
Re: Calibrate Wizard
by ygilquin » Mon Nov 09, 2015 3:57 pm
If you are running iOS9, there is a known bug that will be fixed with upcoming version of the app. Thanks for your patience.
vruniform
by vruniform » Tue Mar 29, 2016 10:47 pm
Any idea when you'll release an update with the calibration working under ios9? In the meantime I've been trying to fiddle with the presets by hand, but unsure of how the values affect the result.
ygilquin
by ygilquin » Fri Apr 01, 2016 4:32 pm
The app is still work in progress.
If you're not sure how to set values, the best is to use cardboard preset, and only set lens separation distance to match your eyes interpupillary distance.
