Opening a Local Kolor Eyes Video on the app
dtzpanomaster
by dtzpanomaster » Fri Feb 13, 2015 6:40 am
Could anyone let me know how can I open a local video on the kolor eyes mobile app ?.
Currently I am using the following url scheme to launch an externally hosted video using the kolor eyes player using my own app.
 koloreyes360videoplayer://video=http://mobile.360heros.com/producers/463060…05686575/9813601418398322/video/video_31b451b7ca49710719b19d22e19d9e60.mp4
But for the above to work the video should be hosted somehwere and streamed into the player.
I am looking for a method to load the locally stored video files on the player itself. Without having to host the video elsewhere.
I tried the following but it doesn't seem to work out.
 koloreyes360videoplayer://video=my_locally_stored_videw.mp4
Could some body help me out ?.
Re: Opening a Local Kolor Eyes Video on the app
by AlexandreJ » Tue Feb 17, 2015 2:19 pm
For local storage, the best solution is transfer through itunes. Easy and fast.
We are working on Kolor Eyes iOS v2.1 which will allow you to download content from your hosting easily. That will be another easy solution.
engineer3334
by engineer3334 » Sat Feb 28, 2015 8:22 pm
Where do you use this koloreyes360videoplayer://video=http:// ... ers/463060…05686575/9813601418398322/video/video_31b451b7ca49710719b19d22e19d9e60.mp4 ?
I am trying to control my Android Kolor Player for player 360 Video from PC. Video will be at local
folder of Kolor in Android and i will start remotely... Failed all times... Any advice ?
dtzpanomaster
by dtzpanomaster » Thu Mar 05, 2015 7:31 am
I am actually using this in android so all you have to do it call that url inside an intent. Just like you would open a web page on a browser in a normal android application.
engineer3334
by engineer3334 » Sun Mar 08, 2015 4:56 pm
That good but I am trying to use Kolor on Android and trying to remote access from Windows PC.
Afa i understood the best way to connect 3 Android devices to control Koloy Eyes is
ADB script on Windows.. Any idea how i can play a movie , pause , control projection method etc ?
( I need to connect all Andoroids on USB to PC. Not wireless )
