Polygon Hotspot Decription   [SOLVED] - View the solution
cgm4967
by cgm4967 » Sat Jan 09, 2016 3:21 pm
I am using v 2.5 v2 on a PC running Windows 10.
I am trying to use a polygon hotspot and have a description come up when the hotspot is clicked. I have created the polygon on my panorama and filled in the Description area of the Polygon hptspot with my text. After that I used the Description plugin found under "Text Zone". I have chosen "Current Spot" under the display of the Description Plugin. Under the Default Polygon Spot Style I chose the Description Plugin under "Action" and "Open current spot description." When I build and click on the hotspot the box comes up but the description text is not there.
Please help.
Cliquetsy
Likes: 106 posts
Liked in: 119 posts
Re: Polygon Hotspot Decription
by Cliquetsy » Sat Jan 09, 2016 3:57 pm
How are you viewing the tour?
cgm4967
by cgm4967 » Sat Jan 09, 2016 4:33 pm
Locally on my hard drive....does it need to be online?
cgm4967
by cgm4967 » Sat Jan 09, 2016 4:40 pm
Just uploaded it...still not working.
Re: Polygon Hotspot Decription  [SOLVED]
by benji33 » Mon Jan 11, 2016 2:45 pm
Just tested as you said without issue.
Try to clear the browser cache. Then refresh the preview.
If issue is still there can you send me the url link please to have a look.
