VRmode hotspots   [SOLVED] - View the solution
manos
VRmode hotspots
by manos » Sat Jan 09, 2016 2:03 pm
Will the shortcoming of only displaying hotspots linked to panoramas be resolved in the final version of 2.5?
Cliquetsy
Likes: 106 posts
Liked in: 119 posts
Re: VRmode hotspots  [SOLVED]
by Cliquetsy » Sat Jan 09, 2016 4:04 pm
Doubt it, since the current versions are RC (Release Candidate), meaning almost final version just smoothing out bugs.
No new features come in between RCs, especially not something as big as adding support of the other types of hotspots.
This is just speculation of course.
Also, you can use image hotspots in VR mode but not have them pop out at your face.
manos
Re: VRmode hotspots
by manos » Sat Jan 09, 2016 5:04 pm
Thanks for the reply. I was hoping to implement VR in an museum tour but zooming in an artwork and displaying its info is essential. Let's hope 2.5.x or later will resolve this major shortcoming.
Re: VRmode hotspots
by benji33 » Mon Jan 11, 2016 1:48 pm
Can only be done with a manual update of the krpano generated code for the VR.
You have to create a layer distorted with the "big" image on the onclick action of a point or image spot and also you need to add a hotspot to be able to close the "popup" with the gaze once opened.
