PTP 2.5 RC 2 - HMD settings problem   [SOLVED] - View the solution
HDP
by HDP » Mon Jan 04, 2016 1:06 pm
an error message appears while in the HMD settings mode after switching from Cardboard 1 to Cardboard 2.
ERROR: plugin(vr_setup_hmd4) loading error: %FIRSTXML%/graphics/null.png
Any ideas how to fix this?
Thanks, Karsten
Re: PTP 2.5 RC 2 - HMD settings problem  [SOLVED]
by benji33 » Mon Jan 04, 2016 2:09 pm
Yes it's a RC2 issue. Will be corrected soon.
You can patch it manually into the YOURTOUR_core_vr.xml file.
Change into the vr_setup_change_headset action the line :
copy(i_hsindex, i); copy(i_headset, hs.caption););
by
copy(i_hsindex, vrheadj); copy(i_headset, hs.caption););
HDP
by HDP » Mon Jan 04, 2016 4:20 pm
Hi Benjamin,
thank you. Now I can switch between the different HMDs.
But now there is no more option to adjust the settings for the HMD.
Can this be fixed also?
Cheers,
Karsten
by benji33 » Mon Jan 04, 2016 4:55 pm
You mean the advanced settings ?
Available in portait and not in landscape ?
HDP
by HDP » Mon Jan 04, 2016 5:33 pm
Yes, I mean the advanced settings.
In portrait mode the only option available is to change the HDM.
In earlier PTP 2.5 versions I was able to access the advanced settings also.
by benji33 » Tue Jan 05, 2016 4:38 pm
Seems strange because this should be available into rc2 version ?!
Do you have a demo online ?
by benji33 » Tue Jan 05, 2016 4:40 pm
