iPhone 4s does not run full screen in 2.5 RC2   [SOLVED] - View the solution
ccmas
Likes: 3 posts
by ccmas » Fri Jan 01, 2016 6:23 pm
Created using Windows 64bit PTP 2.5 RC2
2.5 RC2 fix states:
0005390: [Tour] iPhone 4, 4S, 5, 5S landscape fullscreen issue
The only way I can get a tour working in full screen without top and bottom bars on iPhone 4S is by using ptv locally. It doesn't work full screen in landscape nor portrait.
Not sure if this was 'the issue' but thought I'd better report it.
Re: iPhone 4s does not run full screen in 2.5 RC2
by benji33 » Mon Jan 04, 2016 2:12 pm
What is your iOS version please ? With Safari browser ?
ccmas
Likes: 3 posts
by ccmas » Mon Jan 04, 2016 3:32 pm
Sorry I omitted this info.
iOS is 9.2
Safari browser
by benji33 » Mon Jan 04, 2016 3:49 pm
You're using the fullpage html template ?
ccmas
Likes: 3 posts
by ccmas » Tue Jan 05, 2016 1:36 pm
Yes, I am using the fullpage html template.
On re-building and re-testing I note that when you load it in landscape it is not fullscreen. Then when you turn to portrait it is again not full screen. The when you turn back to landscape it IS fullscreen. I cannot get it to be fullscreen in portrait though unless, as I said, via ptv viewer.
If I load it in portrait it is not fullscreen (has network info at top, then bar underneath with url and refresh icon, at bottom it has < > 'share' icon bookmark and multi window icons) but turn to landscape it IS fullscreen.
Re: iPhone 4s does not run full screen in 2.5 RC2  [SOLVED]
by benji33 » Wed Jan 06, 2016 4:17 pm
If page is loaded in landscape mode the fullscreen can't be reach because iOS doesn't manage the fullScreen API.
iOS has implemented a fullscreen on iPhone only when the device goes from portrait to landscape.
It's an iOS limitation for the fullscreen.
