Kolor User Directory - fail to recognize or create   [SOLVED] - View the solution
bitbyter
Liked in: 3 posts
by bitbyter » Tue Dec 29, 2015 2:45 pm
Hi, I've recently been forced to change laptops and have installed PTP RC2 (Windows7). Problem is it does not seem to recognize the standard location of the user directory (usually c:\Users\XXX\Documents)
When I use the menu in PTP to Open User Directory, it opens c:\ (root) and there is no Kolor folder created. I also tried copying my user directory from old computer into c:\Users\XX\Documents\Kolor
but it does not get recognized and no custom plugins are available
Is there any way to force the folder PTP expects to use ? (i.e. in registry)
Thx, Scott
Re: Kolor User Directory - fail to recognize or create
by benji33 » Tue Dec 29, 2015 4:23 pm
1. Is it Panotour or Panotour Pro which has been installed ?
2. Installed for all users or for a specific user ?
There is no possible registry edit for this directory.
bitbyter
Liked in: 3 posts
by bitbyter » Tue Dec 29, 2015 5:33 pm
It's PanoTour Pro 2.5 RC2 - installed for all users. I'll try uninstalling and re-install just for myself and see if that works..
bitbyter
Liked in: 3 posts
Re: Kolor User Directory - fail to recognize or create  [SOLVED]
by bitbyter » Tue Dec 29, 2015 6:29 pm
Uninstall and re-install with shortcuts for "current user only" seemed to work! Strange, since I'm 99% sure that my last computer had it installed for all users, however it's working now and that's what matters - thanks for pointing me in the right direction Benjamin.
by benji33 » Mon Jan 04, 2016 10:25 am
Thanks for this test I'll report the problem.
