Keepview in PTP 2.5.0   [SOLVED] - View the solution
mjaszo
Liked in: 3 posts
by mjaszo » Fri Dec 04, 2015 10:13 pm
PTP 2.5.0
For the project: http://www.full-frame.pl/vt/151113-4por ... yRoku.html I have different ways of changing panos and would like to keep the view as in GoogleSV. I've changed _core.xml mainloadscene MERGE to KEEPVIEW and what I have is next/previous panorama working OK. Using buttons to the right (pano specified), miniatures and hotspots is not.
Solution http://www.kolor.com/wiki-en/action/vie ... epview_tag seem to be changed in PTP2.5.0.?
What else should be changed?
Thanks!
Re: Keepview in PTP 2.5.0
by benji33 » Tue Dec 29, 2015 12:32 pm
If all equis are aligned (not aligned into PTP) and you don't use any transition on spot the KEEPVIEW should work.
Documentation updated for 2.3.2 and 2.5 here : http://www.kolor.com/wiki-en/action/vie ... epview_tag
mjaszo
Liked in: 3 posts
Re: Keepview in PTP 2.5.0  [SOLVED]
by mjaszo » Mon Jan 11, 2016 7:36 pm
Transitions it was :) Thanks! It's working like a charm:
http://www.full-frame.pl/vt/Mikaszowka/4poryRoku.html
benji33 likes this post.
