Combobox doesn't drop down on windows 10 tablet
bob1010
Liked in: 3 posts
by bob1010 » Thu Dec 03, 2015 4:17 pm
Hi Benjamin,
Done some tests on a windows 10 tablet & discovered that the combo box doesn't drop down when you left click the cursor on the box in the html5 version. The titles did change in the comobox when you click the simple thumbnails though.
The 2.3 flash tours still load ok on the tablets I tried.
Haven't been able to test on a Windows 10 phone yet as not in store here - do you have one you could test on?
here's some test links:
http://www.irisimage.com/360-degree-gal ... -skin-xml/
http://www.irisimage.com/360-degree-gal ... ttage-2.5/
bob1010
Liked in: 3 posts
Re: Combobox doesn't drop down on windows 10 tablet
by bob1010 » Sun Dec 06, 2015 4:19 pm
Tested combo box on the new Windows 10 lumia phone, the drop down menu dropped down but then locked the screen and I had to use the back button to reload the tour so it would rotate again. The simple thumbnails work ok and change the title in the combo box, and the tour rotates fine in 2.5.
Could this bug possibly be sorted in the next update?
by benji33 » Tue Dec 29, 2015 2:07 pm
Can't test on Windows 10 phone for the moment (update is not yet available for our devices) so it's difficult to manage.
bob1010
Liked in: 3 posts
by bob1010 » Tue Dec 29, 2015 5:24 pm
Ok Benjamin, haven't managed to do a test with rc2 version yet, will test it in the local phone shop on Windows 10 phone once I have and let you know the outcome if it helps
Regards,
Rob
bob1010
Liked in: 3 posts
by bob1010 » Wed Dec 30, 2015 2:28 pm
Hi Benjamin, I've done a test in 2.5 rc2, I've set the core value for mobile scale to 1.0, but didn't edited the combo box code for size to see if that was effecting the drop down function on windows 10 phones. I'll test that next time I'm in a phone shop & let you know if the combo box drops down at the smaller scale.
Here is the link to my rc2 test: http://www.irisimage.com/360-degree-gal ... ge-rc2-v1/
Will the following code still need to be edited in the final version of 2.5 to get the combobox larger (in order to achieve the scale that it was in version 2.3) would be great to have a tick box that would scale both the thumbnails & combobox in the style tab if it were possible so that manual editing of 2.3 projects isn't required in order to get the same scaled plugins and for new projects also. This is the code you gave for the scaling of the combobox that would be handy to have a tick box edit for in the style tab.
itemfontsize.normal="14"
itempadding.normal="8"
itemfontsize.mobile="11"
itempadding.mobile="5"
cbdesignscale.mobile="1"
with these lines :
itemfontsize="14"
itempadding="8"
by benji33 » Mon Jan 04, 2016 2:16 pm
Final release will have a checkbox to be able to choose if the global scale for mobile must be used (as 2.5 version) or not (as 2.3 version).
bob1010
Liked in: 3 posts
by bob1010 » Mon Jan 11, 2016 3:40 pm
Hi Benjamin, managed to test my rc2 test tour on a Windows 10 mobile phone, tablet & desktop PC.
On the window 10 phone the combo box drops down when clicked but then freezes & you can't click any title or close the box & you have to reload the page. The thumbnails worked perfectly on Windows 10 phone.
On a Windows 10 Tablet & Desktop computer the combo box doesn't drop down at all, but the drop down arrow changes state from grey to blue, but nothing else happens. Again, Thumbnails all worked perfectly, as did the control bar.
Here's the test link again: http://www.irisimage.com/360-degree-gal ... ge-rc2-v1/
Hope that helps.
Regards,
Rob
by benji33 » Mon Jan 11, 2016 4:58 pm
Thanks. It's a combobox issue. Will be solved into the next krpano player release normaly.
bob1010
Liked in: 3 posts
by bob1010 » Wed Jan 13, 2016 10:42 am
Thanks for letting us Know.
Rob
