Read before posting - Forum rules
There is currently no beta available at the moment
by Annis » Thu Mar 27, 2014 4:43 pm
This sub-forum is for users who would like to give feedback, share their experience or if they have a bug to report, crashes, stability issues, etc... using the beta versions of Panotour / Panotour Pro.
Before posting, have a look at our Troubleshooting page, in case that solves your problem.
You may also want to do a search for a bug, before reporting it. Also make sure that you have the latest beta version installed.
When posting, make sure that you provide as much precise information as possible:
-Your computer specs
-Which version of the software you are using
-How many images, what file format
-What plugins you are using
-When does the crash/problem occur exactly?
-Can you recreate the problem? (If you can, what is your precise workflow)
-Is the same using a different project? If not, what's the difference between the two?
-Screenshots, we love those
-If the software crashed, were you prompted to send us a crash report?
-etc..
Once the issue is solved, check the solved button on the top right corner of the post that provided you with the solution.
Make sure you post one topic per issue, so that they can be dealt with separately.
Thanks,
