Bootstrap Top Navbar Issues   [SOLVED] - View the solution
GD-Steven
by GD-Steven » Thu May 25, 2017 11:51 am
I'm new to Panotour and I'm trying to figure out how to customise the Boostrap Top Navbar Template.
I want certain PanoGroups that the name contains a particular string to be a simple list item that links to the first of the group instead of a dropdown with all the elements shown.
I have tried checking the name of the PanoGroup and if it contains a particular substring then create a list item, this would happen after the if group.isExplicit statement.
For example,
{% if group.isExplicit %}
    {% if "groupsingle" in  group.description.name %}
         ......Create list item with the group name and first pano link
    {% else %}
        .......Create the select dropdown (the code that is already there)
    {% endif %}
    .....Rest of the normal code
{% endif %}
However, when I have tried building the project after this change, it would return saying "if statement improperly formatted".
I have checked the documentation and have tried the if statement with particular strings i.e
{% if "abc" in  "abcdef" %}
Does anyone see what I am doing wrong? Or is there a different method to do what I am trying to do? Or some in-built function that I am missing?
360-compunics-com-ni
Likes: 15 posts
Liked in: 163 posts
Re: Bootstrap Top Navbar Issues
by 360-compunics-com-ni » Thu May 25, 2017 9:50 pm
Not sure which Django version introduced the "in" operator, but i suppose it's because of this that the string comparison does not work as expected. Maybe someone from Kolor can verify this - the plugin documentation links to version 1.1 of the Django builtins, which is from 2009.
Likes: 14 posts
Re: Bootstrap Top Navbar Issues  [SOLVED]
by bdd » Mon May 29, 2017 9:39 am
Sorry, the "in" django operator is not implemented in the grantlee library used by Panotour 2.5.7 .
Grantlee syntax is a Django like syntax, but it's an old one, and it is a simplified one.
http://www.grantlee.org/apidox/differences_django.html
We will see if we can update Grantlee, or if we can add this operator by ourself in a future version .
2 people like this post.
