Which drone for 360 photos and videos?
Discuss cameras used for shooting panoramas, virtual tours or 360° videos (GoPros, DSLRs, one shot cams, etc..) and their various accessoires (lenses, monopods/tripods, etc...).
(EN/FR Forum)
blaugran
by blaugran » Sat Mar 12, 2016 12:58 pm
Hi guys,
I was just wondering what is the easiest way to do 360 photos from the air, and I guess it is a drone. Is there any of You using one? Can You recommend a good drone to start with? Not sure if DJI Phantom series could do the work, and how a bout quality then.
jakedonahue
Re: Which drone for 360 photos and videos?
by jakedonahue » Sat Mar 26, 2016 7:56 pm
I use a DJI Phantom 3 and manually shoot a bunch of images from the sky. In photoshop I replace the sky since the camera on a drone cannot look up (it would just be propellers anyway). Here is an example of one I shot in Portland, OR:
http://pdxpics.com/360/portland
by gkaefer » Tue Oct 11, 2016 12:47 pm
using dji you can use:
dronepan app (inspire & phanotm 3):
https://itunes.apple.com/de/app/dronepan/id1026329337?l=en&mt=8
http://www.dronepan.com/
and flylitchi (inspire, phantom 3 standard+prof+phantom 4)
https://flylitchi.com/
signmaster
Likes: 52 posts
Liked in: 36 posts
by signmaster » Sat May 12, 2018 10:52 am
I use a DJI Mavic Pro, here are some samples. http://360virtualtours.com.au/aerial/
Find the best is to use the DJI Go app and stitch with Autopano or PTGui. With large areas of water XML creator http://www.hdrpano.ch/xml-creator.htm
Steve
martha1188
by martha1188 » Thu Sep 06, 2018 12:14 pm
good one ..
