V1.3 Mac ne démarre plus sous leopard 10.5
Coffre
by Coffre » Sun Nov 04, 2007 10:04 pm
Autopano version mac 1.3 n'arrive plus a se lancer sous os X 10.5, l'icone rebondit dans le dock pour finir par un message d'erreur détail ci-joint :
(merci d'avance pour votre réponse. Coffre)
Process: AutopanoPro [191]
Path: /Applications/Autopano Pro.app/Contents/MacOS/AutopanoPro
Identifier: com.kolor.Autopano
Version: ??? (1.3.0)
Code Type: X86 (Native)
Parent Process: launchd [69]
Date/Time: 2007-11-04 21:51:45.431 +0100
OS Version: Mac OS X 10.5 (9A581)
Report Version: 6
Exception Type: EXC_BAD_ACCESS (SIGBUS)
Exception Codes: KERN_PROTECTION_FAILURE at 0x0000000000000000
Crashed Thread: 0
Thread 0 Crashed:
0 QtCore 0x00c4bec2 QLocale::language() const + 8
1 com.kolor.Autopano 0x00004ee3 AutopanoAppSettings::SetDefaultSettings(SettingsManager&) + 275
2 com.kolor.Autopano 0x000053c1 AutopanoAppSettings::AutopanoAppSettings() + 51
3 com.kolor.Autopano 0x000042a9 AutopanoApp::AutopanoApp(QString const&, int&, char**, QApplication::Type) + 65
4 com.kolor.Autopano 0x0000ec4d main + 73
5 com.kolor.Autopano 0x00002972 _start + 228 (crt.c:272)
6 com.kolor.Autopano 0x0000288d start + 41
Thread 0 crashed with X86 Thread State (32-bit):
eax: 0x00000000 ebx: 0xbffff92c ecx: 0x00000000 edx: 0xbffff92c
edi: 0xbffff920 esi: 0xbffff910 ebp: 0xbffff898 esp: 0xbffff898
ss: 0x0000001f efl: 0x00010282 eip: 0x00c4bec2 cs: 0x00000017
ds: 0x0000001f es: 0x0000001f fs: 0x00000000 gs: 0x00000037
cr2: 0x00000000
Binary Images:
0x1000 - 0x2b8fe4 +com.kolor.Autopano ??? (1.3.0) /Applications/Autopano Pro.app/Contents/MacOS/AutopanoPro
0x6b8000 - 0xa2571f +QtGui ??? (???) /Applications/Autopano Pro.app/Contents/Frameworks/QtGui
0xc32000 - 0xd8fe37 +QtCore ??? (???) /Applications/Autopano Pro.app/Contents/Frameworks/QtCore
0x8fe00000 - 0x8fe2d883 dyld 95.3 (???) <81592e798780564b5d46b988f7ee1a6a> /usr/lib/dyld
0x90070000 - 0x902e9fe7 com.apple.Foundation 6.5 (677) <d182b2cc21817f7e5b6c7a1b3f421a98> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x902ea000 - 0x90361fe3 com.apple.CFNetwork 217 (219) <f3c16ae4b2faeb134957ee96d90dc5ca> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x90362000 - 0x903f4ff3 com.apple.ApplicationServices.ATS 3.0 (???) <fb5f572243dbc370a0ea5efc8e81ae11> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
0x90574000 - 0x90574ffd com.apple.Accelerate 1.4 (Accelerate 1.4) /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x90575000 - 0x90577ff5 libRadiance.dylib ??? (???) <20eadb285da83df96c795c2c5fa20590> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x9073a000 - 0x90774ff7 com.apple.coreui 0.1 (60) /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
0x90775000 - 0x90776fef libmathCommon.A.dylib ??? (???) /usr/lib/system/libmathCommon.A.dylib
0x90777000 - 0x907f6ff5 com.apple.SearchKit 1.2.0 (1.2.0) <277b460da86bc222785159fe77e2e2ed> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0x909bd000 - 0x90a1affb libstdc++.6.dylib ??? (???) <04b812dcec670daa8b7d2852ab14be60> /usr/lib/libstdc++.6.dylib
0x90a1b000 - 0x90a77ff7 com.apple.htmlrendering 68 (1.1.3) <fe87a9dede38db00e6c8949942c6bd4f> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTMLRendering.framework/Versions/A/HTMLRendering
0x90a78000 - 0x90a84ff5 libGL.dylib ??? (???) /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
0x90a85000 - 0x90b66ff7 libxml2.2.dylib ??? (???) <450ec38b57fb46013847cce851001a2f> /usr/lib/libxml2.2.dylib
0x90c12000 - 0x90cddfff com.apple.ColorSync 4.5.0 (4.5.0) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x90cde000 - 0x90d90ffb libcrypto.0.9.7.dylib ??? (???) <330b0e48e67faffc8c22dfc069ca7a47> /usr/lib/libcrypto.0.9.7.dylib
0x90d91000 - 0x90d9fffd libz.1.dylib ??? (???) <5ddd8539ae2ebfd8e7cc1c57525385c7> /usr/lib/libz.1.dylib
0x90da0000 - 0x90efafe3 libSystem.B.dylib ??? (???) <8ecc83dc0399be3946f7a46e88cf4bbb> /usr/lib/libSystem.B.dylib
0x91cfc000 - 0x91da3ff7 com.apple.QD 3.11.49 (???) <ca01e72078d30d6b183aa5224344608b> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
0x91da4000 - 0x91dcbfff libcups.2.dylib ??? (???) <6b61eb99e6f5dd2d66cd224e9f82427d> /usr/lib/libcups.2.dylib
0x91e48000 - 0x91e67ffa libJPEG.dylib ??? (???) <0cfb80109d624beb9ceb3c43b6c5ec10> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x91e68000 - 0x91e6bfff com.apple.help 1.1 (36) <b507b08e484cb89033e9cf23062d77de> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
0x91fd5000 - 0x920f9fe3 com.apple.audio.toolbox.AudioToolbox 1.5 (1.5) /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x9224f000 - 0x92251fff com.apple.securityhi 3.0 (30817) <2b2854123fed609d1820d2779e2e0963> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
0x923a8000 - 0x92401fff libGLU.dylib ??? (???) /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
0x9240a000 - 0x92428fff libresolv.9.dylib ??? (???) <54e6a08c2f108bdf5916fb483d51961b> /usr/lib/libresolv.9.dylib
0x9245c000 - 0x9245cff8 com.apple.ApplicationServices 34 (34) <8f910fa65f01d401ad8d04cc933cf887> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x9248e000 - 0x924cdfef libTIFF.dylib ??? (???) <6d0f80e9d4d81f3f64c876aca005bd53> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x92508000 - 0x92584feb com.apple.audio.CoreAudio 3.1.0 (3.1) <70bb7c657061631491029a61babe0b26> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x92585000 - 0x9285efe7 com.apple.CoreServices.CarbonCore 783 (783) <8370e664eeb25edc98d5c1f5405b06ae> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x9285f000 - 0x92863fff libGIF.dylib ??? (???) <d4234e6f5e5f530bdafb969157f1f17b> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x928a9000 - 0x92d75ffe libGLProgrammability.dylib ??? (???) <ebd2e6c99ec2662b4bdaa3212ab94aed> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dylib
0x92d83000 - 0x92d83ffd com.apple.Accelerate.vecLib 3.4 (vecLib 3.4) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
0x92d84000 - 0x92e4bff2 com.apple.vImage 3.0 (3.0) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
0x92e69000 - 0x92e69ffc com.apple.audio.units.AudioUnit 1.5 (1.5) /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x92e6a000 - 0x92ea7ff7 libGLImage.dylib ??? (???) <2d5ec9fc8b04b7b33f1d40ec83d86bf3> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
0x92ea8000 - 0x92eeafef com.apple.NavigationServices 3.5 (160) <26d03493eac3e290fd1d0fd5ff311863> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/NavigationServices.framework/Versions/A/NavigationServices
0x92eeb000 - 0x92ef3fff com.apple.DiskArbitration 2.2 (2.2) <1551b2af557fdf6f368f93e093933852> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x92ef4000 - 0x92f1efef libauto.dylib ??? (???) <d468bc4a8a69343f1748c293db1b57fb> /usr/lib/libauto.dylib
0x92f1f000 - 0x930e8fef com.apple.security 5.0 (31122) <0759867b3944f1e54ce3d9078bbdb867> /System/Library/Frameworks/Security.framework/Versions/A/Security
0x930e9000 - 0x93143ff7 com.apple.CoreText 2.0.0 (???) <7fa39cd5bc847615ec02e7c7a37c0508> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreText.framework/Versions/A/CoreText
0x93191000 - 0x93198ffe libbsm.dylib ??? (???) <d25c63378a5029648ffd4b4669be31bf> /usr/lib/libbsm.dylib
0x93199000 - 0x932d1ff7 libicucore.A.dylib ??? (???) <afcea652ff2ec36885b2c81c57d06d4c> /usr/lib/libicucore.A.dylib
0x93377000 - 0x933c7ff7 com.apple.HIServices 1.6.0 (???) <d74aa73e4cfd30a08fb169198a8d2539> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x933c8000 - 0x937d8fef libBLAS.dylib ??? (???) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x937d9000 - 0x937edff3 com.apple.ImageCapture 4.0 (5.0.0) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
0x937ee000 - 0x938a4fe3 com.apple.CoreServices.OSServices 209 (209) <89296b20d2db6c180eee073b699e3484> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
0x938a5000 - 0x938a5fff com.apple.Carbon 136 (136) <98a5e3bc0c4fa44bbb09713bb88707fe> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x940b5000 - 0x940befff com.apple.speech.recognition.framework 3.7.24 (3.7.24) <d3180f9edbd9a5e6f283d6156aa3c602> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
0x940bf000 - 0x940daffb libPng.dylib ??? (???) <b6abcac36ec7654ff3e1cfa786b0117b> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x94174000 - 0x9417ffe7 libCSync.A.dylib ??? (???) <df82fc093e498a9eb5490761cb292218> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCSync.A.dylib
0x94180000 - 0x941a4fff libxslt.1.dylib ??? (???) <4933ddc7f6618743197aadc85b33b5ab> /usr/lib/libxslt.1.dylib
0x941a5000 - 0x94231ff7 com.apple.LaunchServices 283 (283) <30168051779817916e04eb8e85fcc17f> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x944db000 - 0x944e2fe9 libgcc_s.1.dylib ??? (???) <f53c808e87d1184c0f9df63aef53ce0b> /usr/lib/libgcc_s.1.dylib
0x944e3000 - 0x94592fff com.apple.DesktopServices 1.4.2 (1.4.2) <ec69c4072b0df6f52ef3f48fadf4c4b8> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0x94593000 - 0x94593ffb com.apple.installserver.framework 1.0 (8) /System/Library/PrivateFrameworks/InstallServer.framework/Versions/A/InstallServer
0x94594000 - 0x945cafff com.apple.SystemConfiguration 1.9.0 (1.9.0) <7919d9588c3b0d556646e555b7193f1f> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x945cb000 - 0x945d7fe7 com.apple.opengl 1.5.4 (1.5.4) <98bccaa83ca5e7101e821b4569a6a2ee> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x94666000 - 0x94716fff edu.mit.Kerberos 6.0.11 (6.0.11) <33c25789baedcd70a7e24881775dd9ad> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
0x9471c000 - 0x9472cffc com.apple.LangAnalysis 1.6.4 (1.6.4) <cbeb17ab39f28351fe2ab5b82bf465bc> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x9472d000 - 0x94737feb com.apple.audio.SoundManager 3.9.2 (3.9.2) <0f2ba6e891d3761212cf5a5e6134d683> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CarbonSound.framework/Versions/A/CarbonSound
0x9481b000 - 0x948aefff com.apple.ink.framework 101.3 (86) <bf3fa8927b4b8baae92381a976fd2079> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
0x94a2f000 - 0x94a30ffc libffi.dylib ??? (???) <a3b573eb950ca583290f7b2b4c486d09> /usr/lib/libffi.dylib
0x94a31000 - 0x94aabff8 com.apple.print.framework.PrintCore 5.5 (245) <9441d178f4b430cf92b67bf346646693> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
0x94aac000 - 0x94dbafe2 com.apple.QuickTime 7.2.1 (7.2.1) <6521656603a30c11ea6d3be1fdde0fa9> /System/Library/Frameworks/QuickTime.framework/Versions/A/QuickTime
0x95397000 - 0x95476fff libobjc.A.dylib ??? (???) <5eda47fec2d0e7853b3506aa1fd2dafa> /usr/lib/libobjc.A.dylib
0x9549b000 - 0x954c8feb libvDSP.dylib ??? (???) <a26683d121ee0f96df9a9d0bfca36049> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
0x954c9000 - 0x9550efef com.apple.Metadata 10.5.0 (398) <4fd74fba0062c2e08ec4b1c10b40ff63> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0x9555f000 - 0x95691fe7 com.apple.CoreFoundation 6.5 (476) <8bfebc0dbad6fc33bea0fa00a1b9ec37> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x95692000 - 0x9571bfff com.apple.framework.IOKit 1.5.0 (???) <5d9b85c55183f9732eb9efc38d18ba53> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x957d8000 - 0x957eefff com.apple.DictionaryServices 1.0.0 (1.0.0) <ad0aa0252e3323d182e17f50defe56fc> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
0x9582a000 - 0x9582affd com.apple.vecLib 3.4 (vecLib 3.4) /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
0x9582c000 - 0x95842fe7 com.apple.CoreVideo 1.5.0 (1.5.0) <bcc3dd0978bb626c26378227740e1e80> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
0x95843000 - 0x95849fff com.apple.print.framework.Print 218 (220) <c35172175abbe554ddadd9b6401351fa> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
0x95862000 - 0x958d6fef libvMisc.dylib ??? (???) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x95925000 - 0x9593dfff com.apple.openscripting 1.2.6 (???) <b8e553df643f2aec68fa968b3b459b2b> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
0x9593e000 - 0x959c5ff7 libsqlite3.0.dylib ??? (???) <273efcb717e89c21207c851d7d33fda4> /usr/lib/libsqlite3.0.dylib
0x959c6000 - 0x95a07fe7 libRIP.A.dylib ??? (???) <bdc6d70bf4ed3dace321b4ff76a353b3> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
0x95a08000 - 0x95dc6fea libLAPACK.dylib ??? (???) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
0x95dc7000 - 0x960cdfff com.apple.HIToolbox 1.5.0 (???) <1b872a7151ee3f80c9c736a3e46d00d9> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x960ce000 - 0x960ceffa com.apple.CoreServices 32 (32) <2fcc8f3bd5bbfc000b476cad8e6a3dd2> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x960db000 - 0x960e0fff com.apple.CommonPanels 1.2.4 (85) <ea0665f57cd267609466ed8b2b20e893> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
0x960e1000 - 0x96778fef com.apple.CoreGraphics 1.351.0 (???) <7a6f399039eed6dbe845c169f7d21a70> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x96779000 - 0x967a8fe3 com.apple.AE 402 (402) <994ba8e884aefe7bf1fc5987df099e7b> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x967a9000 - 0x96b3efef com.apple.QuartzCore 1.5.0 (1.5.0) <363cc63c669523cc3fec577949bb1308> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x96b86000 - 0x96b96fff com.apple.speech.synthesis.framework 3.6.59 (3.6.59) <4ffef145fad3d4d787e0c33eab26b336> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x96b97000 - 0x96cdcff7 com.apple.ImageIO.framework 2.0.0 (2.0.0) <154d4d8cda2bd99518cbabc9f2d69833> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/ImageIO
0xfffe8000 - 0xfffebfff libobjc.A.dylib ??? (???) /usr/lib/libobjc.A.dylib
0xffff0000 - 0xffff1780 libSystem.B.dylib ??? (???) /usr/lib/libSystem.B.dylib
beeloba
by beeloba » Sun Nov 04, 2007 10:54 pm
Bonsoir Coffre,
As-tu essayé la version bêta la plus récente ?
http://en.wiki.autopano.net/Latest_Beta
Il semble que la version 1.3.0 est stable, mais un peu ancienne.
Ton rapport sur le comportement de Autopano Pro V1.4.0 RC 2 sur Léopard nous serait d'une grande utilité.
PS. la prochaine version de la 1.4.0 GM est en cours de réalisation… Elle sera dispo d'ici quelques jours.
Tous les retours de bug sur la prochaine version d'APP et de Léopard seraient bienvenue.
Continue (z) d'indiquer le contexte matériel sur lequel vous êtes SVP :)
by AlexandreJ » Mon Nov 05, 2007 1:25 pm
