flipped image in HDM (OSVR HDK2)
Share your tips, tricks or get help with using GoPro VR Player!
Krbec2
by Krbec2 » Mon Oct 02, 2017 5:41 pm
Hello there.
Just downloaded GoPro VR Player and despite it works almost perfectly (compared to what I was experimenting before) i have one major problem with it.
The image (360° image or video, tested both) is flipped in HMD (on PC screen it looks OK). Any idea how to flip it in HMD so it could be watched properly?
Thanks in advance for any help.
few details ...
.. HMD - OSVR HDK2
.. PC - i7 4.2GHz, 32GB RAM, GF 1080 Ti, 64-bit Win 10
.. GoPro VR runs Steam VR (HMD is visible there)
.. image and IMU works OK on screen, only image is flipped in HMD (googles)
.. reactions on movements works as intented, so on screen everything is fine, in HMD display it feels as Y axis is reverted (but only cause image is flipped, in fact looking down turns view angle towards ground (though ground is on top))
.. tested several images and vids, that are working fine with Oculus
lmartin
Liked in: 9 posts
Re: flipped image in HDM (OSVR HDK2)
by lmartin » Thu Oct 05, 2017 10:06 am
There is no option to flip the HMD rendering, but we could add one for this case indeed.
I assume that you are using version 2.3, can you try with 3.0 RC1 which has an update of OpenVR sdk, does it help ?
Robert_J
by Robert_J » Sun Dec 10, 2017 11:27 pm
I have the exactly the same issue! I'm on a Mac Pro (6-core, 32GB, D700) with HTC Vive and I'm using version 3.0.1. Before the update (Sierra) I used aa DK2 and it worked fine. Now in high sierra DK2 aint working and Vive is upside down, BUT ONLY in the plugin! Works as intended outside of Premiere.
I have tried both backends and other settings but nothing works it seems.
BTW does Adobe immersive environment work on Mac? Can't get it to work and GoPro VR isn't helping much...
Robert_J
by Robert_J » Thu Feb 15, 2018 7:38 pm
so about flipped image, any fix coming?
lmartin
Liked in: 9 posts
by lmartin » Fri Mar 09, 2018 11:24 am
Next release will allow to invert the HMD texture for this particular case.
You will find a checkbox in advanced settings.
lmartin
Liked in: 9 posts
by lmartin » Thu Mar 15, 2018 4:51 pm
It is now available in the version 3.0.3 released today.
Robert_J likes this post.
