Slow decoding in 2.3 & 3
Share your tips, tricks or get help with using GoPro VR Player!
LeonBreen
by LeonBreen » Tue Aug 29, 2017 9:02 pm
In new versions, decoding slow, but in 2.2 there is faster (normal).
Also in 2.2, all the files are reproduced, and in 2.3 and 3.0 it says that the codec none found.
If the VLC component was updated, then probably it's worth get back it.
olivierbo
Liked in: 132 posts
Re: Slow decoding in 2.3 & 3
by olivierbo » Wed Aug 30, 2017 12:46 pm
Have you tried another video backend? Do you have any codecs installed in your system?
Can you give me details about your system (computer brand, operating system and version) and about the video played (file format, codec)?
Feel free to send or share the video file so that we can make tests.
Thanks in advance,
Olivier
LeonBreen
by LeonBreen » Fri Sep 01, 2017 9:07 pm
3.0 RC1 does not seem to require any codecs, but the video in it is slow, unlike version 2.2.
I use the default backend (vlc), others require codecs.
Example video:
Video: MPEG4 Video (H264) 3840x2160 29.97fps 29845kbps [V: Alias Data Handler [eng] (h264 main L5.1, yuv420p, 3840x2160, 29845 kb/s)]
Audio: AAC 48000Hz stereo 317kbps [A: Alias Data Handler [eng] (aac lc, 48000 Hz, stereo, 317 kb/s)]
I checked more sbs video , everything is played slowly in 3.0 RC1, and in 2.2 it's perfect (well, without brakes).
Windows 7 x 64, GPU Nvidia GTX 760, i3 3220. In 2.2, everything is fine. Any codecs are not installed, installed MPC-HC.
olivierbo
Liked in: 132 posts
by olivierbo » Mon Sep 04, 2017 12:32 pm
Thanks for the details. Have you tried on another system?
Cheers,
Olivier
LeonBreen
by LeonBreen » Tue Sep 05, 2017 11:00 am
I have not tried it, but it will be the similar.
lmartin
Liked in: 9 posts
by lmartin » Tue Sep 05, 2017 12:32 pm
Indeed there are important changes with version 3.0, video decoding is only able to decode what the system is able to decode natively, I mean without any additional codecs.
So if you are on Windows 7 you should not be able to decode 4K with version 3.0 because Windows 7 does not support 4K.
We recommend users you to use Windows 10 which is able to decode 4K natively.
Can you check if Windows Media Player decodes well your video please ?
LeonBreen
by LeonBreen » Fri Sep 08, 2017 1:29 pm
Windows 7 perfectly decode 4k video in GoPro VR Player 2.2 or 2D players. This is not related to Windows. Apparently updated to new versions I will not. Thanks.
by benji33 » Mon Oct 30, 2017 3:54 pm
What are the results with the 3.0 released version ?
You can keep the 2.2 or 2.3.1 version installed if needed.
