Best quality & performance VR Player settings?   [SOLVED] - View the solution
Share your tips, tricks or get help with using GoPro VR Player!
mberajas
Likes: 3 posts
by mberajas » Mon Dec 19, 2016 10:17 pm
Hi I need somebody to help me! I have spent very long time testing and looking the way to improve my video's quality. I was convinced myself that I was making something wrong in the filming, until I saw my product with a regular player like windows player, the resolution looks really great, but when I play the video with GoPro VR Player the quality goes down a lot! I know that is not the same, but may be there is something to do to improve it! Is there something to do?
Lionel Laissus
Re: Best quality & performance VR Player settings?
by Lionel Laissus » Thu Dec 22, 2016 10:20 am
Hi
To get a good quality in GoPro VR player/Oculus the resolution of the video should be 4K or higher
mberajas
Likes: 3 posts
by mberajas » Thu Dec 22, 2016 10:32 am
I use always K4! What I need to know what should be the recommended set up of VR Player?
lmartin
Liked in: 9 posts
by lmartin » Mon Dec 26, 2016 12:10 pm
For current version 2.1 of the player, here are the recommendations (and also automatic choices made by the player) :
- on Windows 10 without HMD, I will recommend to use WMF video backend. It benefits of efficient hardware decoding.
- on Windows 10 with HMD, I will recommend to use VLC backend with hardware decoding activated (you have to enable it manually in player preferences). If you encounter issues, you can try to deactivate VLC hardware decoding or to force WMF backend, but be aware that you will not benefit of WMF hardware decoding in this configuration.
mberajas likes this post.
mberajas
Likes: 3 posts
by mberajas » Tue Dec 27, 2016 12:02 pm
Thanks for your answer. What is HMD?
olivierbo
Liked in: 133 posts
by olivierbo » Tue Dec 27, 2016 1:24 pm
HMD means Head-Mounted Display (Oculus, Vive, GearVR)
Best,
Olivier
mberajas
Likes: 3 posts
by mberajas » Tue Dec 27, 2016 3:17 pm
Thanks Olivier, So what can I do to improve the image quality? The specific problem that I have is that the image looks unshaped, the distant images looks blurred. I followed the tutorial directions and set up my GoPro cams with lower sharp, is this correct? may it be the reason because my resolution is not nice?
olivierbo
Liked in: 133 posts
by olivierbo » Tue Dec 27, 2016 3:47 pm
Have you tried my colleagues's recommendations?
Playing with the Protune settings can improve the quality, depending on the weather condition, luminosity, etc) but also the framerate! Only choose 48fps as a strict minimum!
The better choice is 1440p @ 60 fps (5.5K video file) or 960p @ 120fps (4K video file).
Cheers,
Olivier
mberajas
Likes: 3 posts
by mberajas » Tue Dec 27, 2016 3:52 pm
what about the sharppnes, is it okay @ low? And for rendering?
olivierbo
Liked in: 133 posts
Re: Best quality & performance VR Player settings?  [SOLVED]
by olivierbo » Tue Dec 27, 2016 3:55 pm
mberajas
Likes: 3 posts
Large differences in start time when synchronizing?
by mberajas » Sun Jan 01, 2017 11:11 am
Why could it be that I have very large differences in start time when synchronizing?
