Oculus Error on GoPro VR Player
Share your tips, tricks or get help with using GoPro VR Player!
travestytravis
by travestytravis » Fri Nov 11, 2016 7:44 pm
We are attempting to watch content in the GoPro VR player via our Oculus headset. However, videos never load, and the following error message appears in the headset:
"Sorry GoPro_VRplayer.exe is taking a while to load. If this issue persists, please take off your headset and check the app".
We have the most recent GoPro VR player installed on the computer, and we deleted it and re-installed it while troubleshooting.
We also checked in settings and I can verify we enabled external programs for the Oculus headset.
Is anyone else getting this error message? Anyone have any leads on what else we can try doing to fix this?
Thanks!
olivierbo
Liked in: 134 posts
Re: Oculus Error on GoPro VR Player
by olivierbo » Mon Nov 14, 2016 2:42 pm
Are you able to play 360 videos with the player but without the Oculus? Does it only occurs when the Oculus is plugged? Did it work before?
Kind regards,
Olivier
travestytravis
by travestytravis » Tue Nov 15, 2016 12:54 am
Thanks Olivierbo,
Yep, other 360 videos play fine. The only issue is when we try to view the videos on the Oculus.
-Travis
olivierbo
Liked in: 134 posts
by olivierbo » Tue Nov 15, 2016 1:55 pm
Hi Travis,
Have you had a look at the documentation regarding the Oculus configuration and troubleshooting?: http://www.kolor.com/wiki-en/action/vie ... umentation
Also does it occurs with all the videos? Can you test on another system as well?
Thanks in advance,
Olivier
gabrielelen
by gabrielelen » Fri Jan 27, 2017 1:44 pm
I have the same problem.
lmartin
Liked in: 9 posts
by lmartin » Mon Jan 30, 2017 9:22 am
Can you print here what you have in software log please, go to Menu > Help > Software log.
Michael H
Liked in: 5 posts
by Michael H » Fri Mar 31, 2017 10:35 am
Hi
I have similar problems. Gopro VR player on its own works fine, same as the Rift on its own. I basically do not get any head tracking etc. The Gopro VR player has the blue symbol on to indicate that it detects the rift itself, but thats it.
lmartin
Liked in: 9 posts
by lmartin » Fri Mar 31, 2017 1:28 pm
Ok thanks for the log.
Error seems to occur when GoPro VR Player tries to connect to Oculus runtime.
What is the version of your Oculus runtime ? (it is printed in Oculus app, go to Settings > General and scroll to bottom)
Are you using Oculus CV1 ?
Take a look at this useful documentation : http://www.kolor.com/wiki-en/action/vie ... culus_Rift
Michael H
Liked in: 5 posts
by Michael H » Fri Mar 31, 2017 2:13 pm
Hi
I am using the latest drivers etc.
I have now plugged the rift into a different pc which has only one nvidia 1080 in there and it works like a charm.
In the pc which came up with the error message, I have two graphics cards, the top slot has the quadro card, and the bottom one a 1080. Even though the rift is plugged into the 1080, it comes up with the quadro. Tried as well in the Nvidia control panel to force everything to go via the 1080, but no change.
andrewcochrane
by andrewcochrane » Tue Jun 27, 2017 2:29 am
we are having this exact issue on all machines with more than one GPU. The single GPU machines work as expected. Vive works better than Oculus, but we still do not see video in the headset, just the default Vive 3D empty grid that you get when an app is loading.
rossfrederick
by rossfrederick » Wed Oct 18, 2017 9:21 pm
I have the same problem 2 GPU's 1 Quadro M4000 as the main display, and a GTX 1080TI that I plug the Oculus into.
Also, when I unplug all but one display from the M4000 and plug in the Ocuclus to it, nothing shows up on the Oculus, just a black screen.
rvoets
by rvoets » Thu Jan 04, 2018 9:18 am
Same problem here using just a single GPU (GTX 1060 6GB) plugged into an ASRock Z270 Extreme4 motherboard.
Only the music will play when trying to use the GoPro VR Player with the Oculus Rift. And like OP I get the following message:
The GoPro VR Player will hang afterwards making it impossible to check the software log using Menu > Help > Software log
lmartin
Liked in: 9 posts
by lmartin » Thu Jan 11, 2018 9:44 am
I think the problem is that GoPro VR Player runs on the Quadro M4000 while Oculus runs on the GTX 1080 for example.
Things should work if you were using SLI for multiple GPU, but for that you need same GPU models.
Can you try to force GoPro VR Player running on GTX 1080 in NVidia control panel, does it help ?
totaln00b
by totaln00b » Tue Apr 17, 2018 7:23 pm
Hey, so is this ever going to get fixed/has this been fixed/is there any plan to figure this out?
