Kolor Eyes 1.6 & GoPro Player w/ Premiere Pro
Share your tips, tricks or get help with using GoPro VR Player!
premiereohio
by premiereohio » Thu Sep 08, 2016 11:58 pm
I'm looking for a solution to stop the auto opening/starting of both Kolor Eyes and GoPro VR Player when opening Adobe Premiere Pro. I don't use VR all the time and these apps opening each time...just to be closed is a pain in the neck. I've looked in all the settings, but don't see any options to shut this off.
Any help is appreciated. Thanks in advance!
lmartin
Liked in: 9 posts
Re: Kolor Eyes 1.6 & GoPro Player w/ Premiere Pro
by lmartin » Fri Sep 09, 2016 9:05 am
You can untick the plugin in Premiere preferences : http://www.kolor.com/wiki-en/action/vie ... the_plugin
wooddy64
by wooddy64 » Mon Oct 30, 2017 11:11 am
Hello, even, we activate it, for me i can see the plug in activate, i can see the viewer but not the plug in.
wooddy64
by wooddy64 » Mon Oct 30, 2017 3:36 pm
Hello, i already try but nothing happen, and when I click to setup, nothing happen
wooddy64
by wooddy64 » Mon Oct 30, 2017 5:06 pm
Miss plug in VR gopro
wooddy64
by wooddy64 » Mon Oct 30, 2017 5:45 pm
by benji33 » Thu Nov 02, 2017 10:48 am
Have you tried to uncheck GoPro VR Player then apply. Then open preferences again and check it to restart GoPro VR Player?
The plugin is the player loaded with shared memory to preview what you are looking into Premiere.
wooddy64
by wooddy64 » Fri Nov 03, 2017 7:19 pm
I tried but nothing appears ! :/
Do you have other solution?
by benji33 » Mon Nov 06, 2017 11:46 am
Is it possible to tell me what happens on you screen when the plugin is active?
Do you have the GoPro VR Player which is loaded on the screen? Because it is into your screen capture.
wooddy64
by wooddy64 » Mon Nov 06, 2017 3:49 pm
When i open the project in Premier, the "Go pro Vr player" appears and show me the video i have in my timeline.
si i don t have a problem for work with the Player VR.
The problem is, i can t have the plug in "Go pro VR" in my effect
and also, i have a friend who have the same problem.
I called adobe, they say, only kolor (you) can fixe the problem :)
I case, my email is thibvde@gmail.com
by benji33 » Tue Nov 07, 2017 10:05 am
"When i open the project in Premier, the "Go pro Vr player" appears and show me the video i have in my timeline.
si i don t have a problem for work with the Player VR."
For the GoPro VR Player plugin this is the working status.
So it's ok.
You talk about the GoPro VR Plugins (Layer, Horizon, Reframe) perhaps ?
If yes what is your version (major, minor, beta ?) of AutoPano Video with the plugins installer, please ?
wooddy64
by wooddy64 » Tue Nov 21, 2017 4:43 pm
i install beta auto pano video 3 beta, some friend download it with no problem for have the "Go pro VR plugins (layer, horizon, Reframe).
