Maybe that´s a silly question . .   [SOLVED] - View the solution
by klausesser » Wed Aug 29, 2018 7:50 pm
I gave an USB-stick to a client for having him run a tour locally without needing access the the web.
Error. This didnt work.
When i render the tour also for ptv - will it work for him this way?
I guess it NEEDS to be possible running a tour offline on a client´s device any time he wants or
needs it to run without access to the web.
I cannot expect a business-partner/client to be blessed with any IT-skills . . . :cool:
thanks in advance for any information,
(used the search option already)
Re: Maybe that´s a silly question . .  [SOLVED]
by benji33 » Thu Aug 30, 2018 8:51 am
No it's not possible in most of the cases. Internal memory or internal SD must be used for that.
Only few Android devices will be able to access a "ptv" directory on usb stick.
