PTV disappeared from Google Play
bonapictura
Liked in: 4 posts
by bonapictura » Mon May 07, 2018 11:19 am
I want to install PTV on my android phone but I can't find it in Google Play.
Did Kolor take it down? When will it be back?
baerlinteam
Re: PTV disappeared from Google Play
by baerlinteam » Mon May 07, 2018 4:33 pm
Yes, i want to ask the same one!
I can not found the App in the Google Play Store???
What's wrong?
signmaster
Likes: 48 posts
Liked in: 34 posts
by signmaster » Tue May 08, 2018 2:39 am
Also after the app for an android phone
Steve
Joffrey
by Joffrey » Thu May 10, 2018 12:04 pm
Hi!
same here! Cannot find the viewer on the store anymore...
Is there another simple way to keep visits on the phones offline?
Thanks a lot.
Joffrey
ThomasK
by ThomasK » Thu May 10, 2018 7:14 pm
