Invalid PTV
vickywrig
Invalid PTV
by vickywrig » Tue Apr 24, 2018 8:03 pm
This is driving me mad!! I have tried the zip file process, replacing the html and data, but it still doesn't work. I have tried the krpano viewer, doesn't work. It does open in a Firefox webserver. But I really want the ptv to work!!! Ahhhh....
Is it anything to do with programme running on a Virtual Box?
This is the debug file just for info;
[0725/111602:ERROR:resource_bundle.cc(691)] Failed to load C:\Program Files\Kolor\Panotour Viewer 1.1\qtwebengine_resources_100p.pak
Some features may not be available.
[0725/111603:ERROR:resource_bundle.cc(691)]
Failed to load C:\Program Files\Kolor\Panotour Viewer 1.1\qtwebengine_resources_200p.pak
[0725/111603:WARNING:resource_bundle.cc(304)] locale_file_path.empty()
[0725/111608:ERROR:
[0725/111609:ERROR:resource_bundle.cc(691)] Failed to load C:\
[0725/111609:WARNING:resource_bundle.cc(304)] locale_file_path.empty()
[0725/113211:ERROR:resource_bundle.cc(691)]
[0725/113211:ERROR:resource_bundle.cc(691)] Failed to load C:\Program Files\Kolor\Panotour
[0725/113211:WARNING:resource_bundle.cc(304)] locale_file_path.empty()
[0725/113213:ERROR:resource_bundle.cc(691)] Failed to load C:\Program
[0725/113213:ERROR:resource_bundle.cc(691)] Failed to load C:\Program Files\Kolor\Panotour Viewer 1.1\qtwebengine_
resources_200p.pak
[0725/113213:WARNING:resource_bundle.cc(304)] locale_file_path.empty()
[0725/121915:ERROR:resource_bundle.cc(691)] Failed to load C:\Program Files\Kolor\Panotour
[0725/121915:ERROR:resource_bundle.cc(691)] Failed to load C:\Program Files\Kolor\Panotour Viewer 1.1\qtwebengine_resources_200p.pak
Some
[0725/121915:WARNING:resource_bundle.cc(304)] locale_file_path.empty()
[0725/121919:ERROR:resource_bundle.cc(691)] Failed to load C:\Program Files\Kolor\Panotour Viewer 1.1\qtwebengine_
resources_100p.pak
[0725/121919:ERROR:resource_bundle.cc(691)] Failed to load C:\Program Files\Kolor\Panotour Viewer 1.1\qtwebengine_resources_200p.pak
available.
[0725/121919:WARNING:resource_bundle.cc(304)] locale_file_path.empty()
Re: Invalid PTV
by benji33 » Wed May 02, 2018 9:17 am
Is it a crash when opening the App on a Windows desktop or When loading the PTV file on it?
Doesn't work with a new PTV file?
Do you have spaces into your project file name (field into the BUILD screen)
