PTV won't work on my iPad Air
Cableoffcut746
by Cableoffcut746 » Mon Mar 19, 2018 10:57 pm
Hi, I was able to download and install your PTV on my iPad, but it doesn't register in the settings App list, so I can't enable file sharing with it. And currently the iPad won't even recognise files with the PTV suffix.
Though at least, it works really well on my Android tablet.
Clément_S
Liked in: 6 posts
Re: PTV won't work on my iPad Air
by Clément_S » Wed Mar 21, 2018 1:35 pm
Hi and welcome to the forum.
Panotour Viewer is a very limited offline testing tool that is not updated on a regular basis. As such it may not be compatible with the latest iOS versions. May I know what iOS version you are running on your iPad?
Please note that the mobile versions of Panotour Viewer have some limitations:
- .SVG icons are generally unsupported.
- Video unsupported on iOS
- PDF files unsupported.
- Panotour Viewer uses your device's native browser to view the tour, not the default one, and this native browser may not meet the requirements to view a virtual tour (WebGL or CSS3D support).
- Compatibility with VR Mode. Panotour Viewer uses your device's native browser to view the tour, and this native browser may not support the WebVR api, VR Mode is deactivated is this is the case. Also make sure your mobile meets all the requirements for using VR Mode at all, listed here: http://www.kolor.com/wiki-en/action/view/Panotour_-_Notions_-_VR_Mode#MobileVR
Best,
Clément
Cableoffcut746
by Cableoffcut746 » Thu Mar 22, 2018 1:40 am
My iPad uses IOS version 11.2.6.
Clément_S
Liked in: 6 posts
by Clément_S » Thu Mar 22, 2018 9:13 am
Thanks for the information, we will investigate this issue.
KateLloyd
by KateLloyd » Sun Apr 15, 2018 1:29 pm
nainasu
by nainasu » Sun Aug 19, 2018 10:48 am
I have also tried PTV and yes, it seems not working; help asap.
