Invalid PTV file
hoehn
Invalid PTV file
by hoehn » Fri Jan 12, 2018 7:39 pm
panotour viewer says the ptv file is invalid.
Only thing i noticed is that the file is smaller than the tour i exported earlyer.
Btw. I just wanted to use the viewer because a client is not able to open the tour in the browser (security issue). I never found a solution for this situation too! if anyone could help with that too please. its always luck if it works offline.
Re: Invalid PTV file
by benji33 » Fri Feb 23, 2018 12:36 pm
Open the tour into Firefox from filesystem.
Or try to generate again the PTV file. As PTV is an archive the size should be among the same.
