XML Parsing failed in Microsoft edge
DC0123
by DC0123 » Wed Jan 10, 2018 8:30 am
When I upload a panotour on the web, I get the error "FATAL ERROR: /tours/data/41 - xml parsing failed" only on Microsoft edge. It works well on all the other Web browser. One thing is when I open the panotour in local, it works on Edge. I don't know where I should continue my investigations.
Do you have an Idee where I could continue my investigations?
I have the following version:
Panotour Pro V2.5.9 64bits
KRPano 1.19
Best regards
David
Re: XML Parsing failed in Microsoft edge
by benji33 » Fri Feb 23, 2018 12:34 pm
Please check your browser console (F12 on windows) to see if there is any error.
Is the xml file in the right read format on the server ? Can you open it into Edge with its url ?
