Video is not completely in the tour?   [SOLVED] - View the solution
saarikor
by saarikor » Wed Oct 25, 2017 1:39 pm
I use PTP with Windows to build tour that contains 1 video. But when I try to play video it only shows 25s of 38s. I check the data folder and it says the vide length is 38s but when I play it, it is only 25s!?
Re: Video is not completely in the tour?  [SOLVED]
by Annis » Wed Oct 25, 2017 1:49 pm
Please see Panotour's troubleshooting page: http://www.kolor.com/wiki-en/action/vie ... il_the_end
This however has nothing to do with the Panotour Viewer app.
