can't install ptv after uninstalling   [SOLVED] - View the solution
storymage
by storymage » Fri Jul 28, 2017 4:27 pm
hello everyone
i created a tour and opened it with ptv several times. i made modifications to the tour and rendered it and opened those also a few times. after 4-5 times repeating this process, i received the failure message: can't read file. from this point on i couldn't open earlier files that i could previeously view either. so i thought to have a software problem.
i uninstalled ptv and tried to install it again. however this is not possible, the installation process stops saying repeatadly not being able to overwrite this and that viewer.exe type files.
anybody had this experience before? i appreciate every feedback. thanks.
best
arnold
Re: can't install ptv after uninstalling  [SOLVED]
by Annis » Mon Jul 31, 2017 9:19 am
Have you tried rebooting your computer?
I've never had anyone report this behaviour.
As for the Cannot Read File issue, this happens when you are previewing the tour from Panotour and also try to to preview the PTV. They use the same server. http://www.kolor.com/wiki-en/action/vie ... AD_FILE.22
storymage
by storymage » Mon Jul 31, 2017 9:32 am
hi Annis
wow :)
good guess! i restarted the computer and now it works. many thanks!
best
arnold
Annis likes this post.
