Have a problem using Panotour Viewer? Have you encountered a bug that needs fixing? Please post it here. Des difficultés à utiliser Panotour Viewer ? Avez-vous découvert un bug qui doit être fixé? Postez les ici.
We have the following problem: we use chrome to open a website with 360 videos. From time to time, there is this message: Rats Web GL hit a snag and it says we have to reload or ignore.
Tried to disable Hardware acceleration but the videos played quite sluggish afterwards.
Is this using Panotour Viewer? Or is this online? If it's online can you share the link? Always the same computer? What is your chrome version, hardware specs and PTP version?
The content is on a local webserver installed on another computer at the client's premises(same LAN). The computer has these specs: Windows 10 Pro 64, i5-7400 , 8 GB RAM and GeForce GTX1050 Ti. Chrome version is: 59.0.3071.115 Panotour Pro version used in creating the content: 2.5.7
When you have the urge to know about the latest videos then you can use this forum very bravely. I am using buyessayonline that are supporting me according to their demands.
