Panotour do no generate normal PTV
fatefull
by fatefull » Tue Jul 11, 2017 8:17 am
Hi there.
I have a Panotour Pro V2.3.2 64bits and meet some problem. I have a tour with 265 panoramas with 3 groups. All panoramas has unique english or number name, and Panotour don't generate normal ptv file, it's only generate small ptv file with 230 Kb size. I cant understand why this happend because early i did another project and everything was ok. Can someone tell me how fixed it?
https://yadi.sk/i/tPIVVela3KwGZE this is how build window look like
https://yadi.sk/i/eJj3SdJe3KwGgd this is how tour window look like
https://yadi.sk/i/leziYsHF3KwGnZ and this is how ptv-file look like
Re: Panotour do no generate normal PTV
by Annis » Tue Jul 11, 2017 11:20 am
You're on Windows, so you can change the file type of the ptv to .zip and open it (don't extract, just enter it) and check the files.
If some are missing, like the panorama folders and files you can add them.
http://www.kolor.com/wiki-en/action/vie ... g_your_PTV
