Panotour Viewer Freezes OSX
kevinpdavies
by kevinpdavies » Thu May 04, 2017 6:46 am
I created a tour with PTP 2.5.7 on OSX. I created a TPV file.
I downloaded and installed the latest Panotour Viewer 1.1 for OSX and opened this TPV file. I click Open in Browser and it opens in Safari OK. The first pano starts to rotate but gets slower and slower. Eventually the computer stops responding - no mouse movement or response to keyboards.
Eventually I had to hold the power button to restart OSX. This happens reliably every time I run the tour.
Re: Panotour Viewer Freezes OSX
by Annis » Thu May 04, 2017 8:48 am
Always with the same tour? Or any PTV?
It looks like you will have to use KrPano Testing Server instead of PTV to view your tours locally.
kevinpdavies
by kevinpdavies » Mon May 08, 2017 1:52 am
Thanks for the quick response Annis.
I tried with another tour and the same problem occurred.
This entry occurred in the system log just before it froze - I don't know if it is any help:
May 8 10:10:11 vlan-2670-10-17-35-41 PanotourViewer[2347]: assertion failed: 16E195: libxpc.dylib + 74307 [ABC45890-DA23-3A4A-B50B-1384BD4CBBDF]: 0x89
I wanted to be able to distribute our tour to a group of school students who will not be able to access our web version behind our university firewall. Apart from setting up a public web site, is the KrPano testing server the best option?
Thanks.
by Annis » Tue May 09, 2017 8:43 am
Yes the KrPano Testing Server would be the best option in this case.
