How can I upload a 6gb PTV Tour ?
SBV360VR
by SBV360VR » Tue Apr 25, 2017 3:04 pm
Hello All
I need to upload a 6gb PTV to to an android device, but it use fat32 and it won't accept files bigger than 4GB.
Is there any turn around to upload it ?
Thanks.
Re: How can I upload a 6gb PTV Tour ?
by Annis » Tue Apr 25, 2017 4:31 pm
Even if you manage to get it on your device I'm not sure such a huge PTV will even run on your android device!
You could maybe try downloading it from a website onto the device? But that could take a while and I'm not certain it'll be readable.
