problems with spot range plugin
pitigarcia
by pitigarcia » Thu Apr 06, 2017 9:50 am
good morning, i got one question. I´m using panotour viewer in mobile without internet using vr mode. There is a problem rendering tour with spot range plugin, when i generate the file ptv and load it in mobile, the images in vr mode not appear and show error. Do you know something about it?
thanks in advance
Re: problems with spot range plugin
by Annis » Thu Apr 06, 2017 10:01 am
What about the tour when it isn't in PTV, does the spot range plugin work?
PTV is a very limited player, only intended for internal testing.
pitigarcia
by pitigarcia » Thu Apr 06, 2017 10:04 am
Work fine when it isn't in PTV.
The idea is to use vr mode on a mobile phone without internet, but I see that it can not. Thank you
Sokobanja
Liked in: 6 posts
by Sokobanja » Thu May 11, 2017 1:51 pm
I know where is the problem.
you must manually open .ptv file using some program. (I am using WinRar on my PC. You can use MacBetter if you are using MAC)
Go to the folder \tournamedata\graphics\alpo.spotrange-v0.0.3 in .ptv file
and drag and drop missing folders with images (vrttoltips or vrimages)
Your program will add missing files and folders there and rebuild your .ptv file.
Thats it.
Cheers
2 people like this post.
