Example Virtual Tour   [SOLVED] - View the solution
Roshan
by Roshan » Thu Mar 02, 2017 4:25 am
Hi there
I have recently downloaded the Panotour Viewer from the Apple Store.
When i open the app, it said i was able to download and example to test out the application, and directed
me to the Kolor Download Website.
Can someone share with me a file, so that i can test out the viewer?
thanks
Roshan
Re: Example Virtual Tour  [SOLVED]
by Annis » Thu Mar 02, 2017 9:59 am
Here's one: http://www.kolor.com/virtual-tours-file ... ffices.ptv
PTV files are essentially a zip file of your tour which is read through the Panotour Viewer App.
Roshan
by Roshan » Thu Mar 02, 2017 10:09 am
Hi Annis
Thank you for the example.
Surprise that i need 2 different logins for Forum and My account :)
Roshan
by Annis » Fri Mar 03, 2017 9:05 am
Yes the forum and user accounts are separate because they use different databases and the forum requires a username to be used, which in your user account the username is your e-mail. Most users wouldn't want their e-mail displayed in a public forum.
