VR MODE - Can't select a VR headset or set custom
royercas
by royercas » Sun Dec 11, 2016 6:03 pm
Hi guys,
Can't select a VR headset or set custom, please see attached
Can do "adjustments" but can't see the VR headsets pictures (as show in desktop testing ?vr).
I'm testing this in a Sony Xperia Z3 smartphone.
Also, just in case, a 360 Utopia VR headset (supposed to be 100% with google's cardboard).
Any idea?
Re: VR MODE - Can't select a VR headset or set custom
by Annis » Mon Dec 12, 2016 10:01 am
Since I don't see any watermarks on the scene in the back, you can't be using the trial version which does currently have this issue in VR Mode.
Are you using a custom HTML file? viewtopic.php?f=97&t=33369#p191078
Why post this in Panotour Viewer? Are you viewing through Panotour Viewer or is it online?
If through PTV, can you try online as PTV is really limited?
marroj
by marroj » Fri Dec 16, 2016 10:20 am
I have the same problem but i need to use a vr mode.
Now i use a demo version (but if it will work i will buy a full licence).
My problem is:
i have a projekt:
i open the tour, and it's ok:
but when i open a VR mode i have that screen:
and can't do anything more. just see the menu of mobile device (inches of screen, cardboard model etc.).
What can i do to see my project (offline) on mobile in VR tour version ?
Please help.
by Annis » Fri Dec 16, 2016 11:12 am
In the trial version it's a bug in the encryption of the files: viewtopic.php?f=92&t=34082&p=191077#p191077
There is no workaround for the trial version.
