debug.log after opening ptv file   [SOLVED] - View the solution
frank007
Likes: 12 posts
by frank007 » Thu Mar 10, 2016 9:25 am
Hi folks,
after opening my ptv file a new file is created in the same directory with this message:
[0310/092213:ERROR:resource_bundle.cc(691)] Failed to load C:\Program Files\Kolor\Panotour Viewer 1.1\qtwebengine_resources_100p.pak
Some features may not be available.
[0310/092213:ERROR:resource_bundle.cc(691)] Failed to load C:\Program Files\Kolor\Panotour Viewer 1.1\qtwebengine_resources_200p.pak
[0310/092213:WARNING:resource_bundle.cc(304)] locale_file_path.empty()
[0310/092215:ERROR:resource_bundle.cc(691)] Failed to load C:\Program Files\Kolor\Panotour Viewer 1.1\qtwebengine_resources_100p.pak
[0310/092215:ERROR:resource_bundle.cc(691)] Failed to load C:\Program Files\Kolor\Panotour Viewer 1.1\qtwebengine_resources_200p.pak
[0310/092215:WARNING:resource_bundle.cc(304)] locale_file_path.empty()
What is that?
Thank you
Frank
DArt
Re: debug.log after opening ptv file  [SOLVED]
by DArt » Thu Mar 10, 2016 9:47 am
It isn't important, just debug info. It is not an error of PTV. :)
frank007 likes this post.
frank007
Likes: 12 posts
by frank007 » Thu Mar 10, 2016 9:49 am
ok, thanks! But I will hand over this file to my client. So he might look at it and thinks I did a bad work?
