Have a problem using Panotour Viewer? Have you encountered a bug that needs fixing? Please post it here. Des difficultés à utiliser Panotour Viewer ? Avez-vous découvert un bug qui doit être fixé? Postez les ici.
Created using Windows 64-bit using Panotour 2.5 RC2
Using in ptviewer on Android 5.0.2 device. Changing from portrait to landscape or vice versa at any stage in tour causes tour to revert to either ptviewer initial screen or splash image - effectively re-starting the tour every time.
