Panotour Viewer beta
leshemnoam
by leshemnoam » Mon Dec 01, 2014 9:32 am
i tried to download Panotour Viewer for android using the steps described on the sticky in this board but google play come up with message that the app is not found. has the beta test period over? Or has google removed it?
How can I download it?
As i can't test it can you tell me if it supports google cardboard? And if not is this something you would consider?
DArt
Re: Panotour Viewer beta
by DArt » Mon Dec 01, 2014 3:21 pm
First be sure that you are correctly connected to your google account (the same than your phone). Then, check that you have joined the beta group. There is a slight delay on google after joining to allow you to download the file, it can take up to several hours.
I have just checked, application is still on google play at https://play.google.com/store/apps/deta ... tourviewer
Cardboard will be available in PTV when PanotourPro will support it (WIP).
