How can I edit the .ptv archive content
pjehan
by pjehan » Sat Sep 27, 2014 11:25 am
I'd like to edit the generated .ptv archive content.
I've try to unzip it and then edit some file but when I am trying zip it again, I can't open it with the Viewer (I created a .zip file and then change the extension to .ptv).
Is it possible to edit .ptv content and how?
Regards,
Pierre
Likes: 14 posts
Re: How can I edit the .ptv archive content
by bdd » Mon Sep 29, 2014 11:17 am
pjehan wrote:Hello,
Regards,
Pierre
Yes it is possible to edit a ptv file.
And the way to do it is the way you did it : unzip, modify, zip.
Can you share with us the zip file you created ?
by benji33 » Mon Sep 29, 2014 12:28 pm
Zip must be done with default/standard zip compression and .pti/.html and data directory must be at the top level of the zip never into a subdirectory created by an zip extract for instance.
http://www.autopano.net/wiki-en/action/ ... TV_file.3F
